I went to export a SubD model from Rhino to keep working with it in Modo. The only way I know how to do this is _ExtractControlPolygon and export that as either OBJ or FBX. OBJ has been broken for a while and this week FBX broke too.
I know OBJ has been broken so I have not been using it, but it wasn’t this broken, now it seems like a rogue file export that no one is watching or something.
I’ve been using FBX instead, but today I found this weird message, in V7:
Can you please give these issues priority and be part of a weekly build Q&A test before releasing a weekly build? We need file imports-export to work to do our work.
for that particular cube yeah the problem goes away, by introducing another problem, look what happens with the Ngons in my file:
I export this (right cube has Ngons)
Also what about solving those weird normal maps generated from extract control polygon. We do want good/usable normal maps. We don’t understand why _ExtractControl polygon is grabbing the normal maps from the smooth SubD. Any reason/utility on that?
@gustojunk - I think you mean that the vertex normals are welded on the extracted control polygon, correct? Not having those welded seems not to affect SubD creation (from them) in Rhino - if it is OK downstream as well (Unweld, 0 degrees to test) I imagine that can be fixed - I do not know if there is any particular need to weld these.
Hi Gustavo - can you please close Rhino, and run a repair on the WIP inastallation via the Windows control panel > Programs? Does that sort anything out for fbx?
