Hello everyone. I want to dimension a building footprint. The paper size would be A0 and I want to apply the 1:200 scale. How would I do that? If I dimension the floor plan at a scale of 1:1 and then scale it manually at a scale of 1:200, the dimensions are automatically adjusted. I don’t want this. I want the real dimensions, not the scaled dimensions. I hope you understand me. Many Thanks.
Do not scale your model - always keep it at 1:1.
You are going to want to create a layout page of the building footprint, size A0. You can then create a detail on the layout page at 1:200. Do your dimensioning on the layout page - it will show the real 1:1 dimensions.
See the online help/tutorials for layouts.
https://wiki.mcneel.com/rhino/layouts5
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/layout.htm?Highlight=layout
You can also print directly at a desired paper size and scale without creating a layout.
Make the viewport which you want to print the active viewport.
Print command Rhinoceros Help
Select the paper size
Select the scale
Etc.
I don’t know how to scale the floor plan to 1:200 after dimensioning without changing the values. Can you help me pls?
Just watch one of these, that’ll probably answer your question: https://www.youtube.com/results?search_query=rhino+layouts
