I have no issue using print in the model view and adjusting the scale from the print options but when I print from a layout viewport then the scale option uses the size of the layout rather than the actual dimensions. Is there a way to still print from layout but scale it with the real dimensions? Thanks!
In a Layout, the Details are set to a specific scale and then normally “Locked”. Then when the Layout is printed at 1:1, the scaled Details on that Layout come out on paper at the desired scale.
