Can’t disconnect wires from widgets
Am I doing something wrong or is this a bug in GH?
I press CRTL + drag (the minus arrow cursor appears), but the wire doesn´t disconnect.
What do you mean with widget?
And just a simple thing… make sure you don’t have two identical components on top of each other.
The image below illustrates my simple setup:
Can´t disconnect “Number Slider” from “Kinks”.
You have to drag all the way to the source. Simple “-’ won’t do.
Alternatively: detach by right click and pick the source.
