The command you need to use is SubDFromMesh
That gives you the Rhino-nurbs-SubD result.
And you want to convert that to nurbs then use the ToNurbs command.
I would like to learn about Boolean operations in SubD (mesh). What in the end are the edges? Can anyone try to subdivide the mesh? If possible, with screenshots ā¦
Youāre good! Of course you are acutely aware. Iām just being a tongue-and-cheek wise arse, as usual. Thanks for being a good sport! I know you are a good thinkerā¦
You still describe a rat-race, IMO, that the human race is inherently a part of, to one degree or the other, and perhaps inextricability attached. Such is life. Good to have a niche youāre happy with, regardless.
Now get back to work!!!
The lease on my EV is up year end. VW is on the right path finally, as hard as that may be on those involved. I just might want one to get from here-to-there in, eventually, to continue greenwashingā¦ @Lagom. Unless I fall in love with the iPace firstā¦wait, thatās a rat-race moveā¦
THAT
There is always Marsā¦ Short TLSA, apply the āwinningsā to a ticketā¦
=) Iām amazed the the concept of falling in love with a car, even tongue-in-cheek, can persistā¦ I see debris that is slightly different than the next bit of debris, all of it a distraction.
And I am amazed by NOT falling in love with a carā¦ Imagine hom many hours the average Joe has to spend working to afford one, so when understanding how much freedom is lost in obtaining one then you better love it!
the Judas of modern times, while long transport boats with junk you donāt need and planes filled with people going to places they have no reason to be, are running non stop while polluting far more than any short traveling carpark ever willā¦
The whole classic SubD workflow (regardless whether mesh or limit surface based) tries to avoid Booleans at any rate. One plans ahead and if one really needs to cut a hole one needs to rebuild the cage, so that it remains valid. Youāll find many videos on that topic.
Hereās a very simple sample which shows that Boolean operations break the topology ā the resulting border triangles make things all lumpy when subdivided.
Sensible when feasible! I thought thatās where you were going.
The ādesirableā owned car is likely toast anyway, eventually, for the masses. Mobility via self driving public transport, and ubiquitous uniform pods, all powered by the sun.
