Hi
I try zip file sbsar, then import into rhino 7. but it’not work
Need advice
https://1drv.ms/u/s!AuAcyL2kNiCPj9tnaay_Maz1tGptZA?e=yvo8hz
Thank
Travis
Hi
Need advice
Thank
Travis
Concrete ?
Loads here, but with old hardware a little slower.
Hi
This is fabric material.
Travis
Hi Travis,
To provide clarity, You have …
Rhino system-requirements
SB-Importer-Plugin trough _PackageManager installed.
and *.sbsar file loaded trough importer with *.sbsar extension ! not as *.zip
And wait until the material is loaded
Hi
Oh they release new version. I install new update but error when I restart
Did you see fabric material when imported?
Travis
If the Details dialog tells you the ID is already in use you need to remove the old one. To find out the location follow: Tools > Options > Plug-in Manager, select the Substance plug-in, press details link in its info panel, then click the folder path name. It should open the folder where the RHP file is located. Shut down all Rhino instances, then remove the RHP file. Restart Rhino.
Thank’s nathanletwory
lovely texture
You should see it with a pattern on it
