[Bug?] Why does _ExtractAnalysisMesh change Draft Angle vertex colors?
I’m not sure whether this is a bug or I’m missing something.
I need to generate a mesh with Draft Angle Analysis vertex colors applied. I’m using the _ExtractAnalysisMesh command, but as shown, the result (left sphere) differs from the original surface (right sphere) with _DraftAngleAnalysis enabled.
Rhino Version 8 SR32 (8.32.26160.13001, 2026-06-09)
This is the sample file I’m working on: DraftAngleAnalysis.3dm (639.6 KB)
Thanks for the support!
bump
Can you share the exact steps you followed to get to the situation in the file.
Note that if you change CPlane or viewport that has a different CPlane and draft angle analysis uses the CPlane Z-direction for angle analysis (like in the screenshot) this may change the results from one invocation to the next.
Hold on. I’m seeing it too! Here is a ticket for this https://mcneel.myjetbrains.com/youtrack/issue/RH-96404
For anyone running into the same issue, my temporary workaround is to use Rhino 7 (7.38.24338.17001, 2024-12-03), since the bug doesn’t seem to be present there.
RH-96404 is fixed in Rhino 8 Service Release 35
