Bug when Copy-Pasteing from one block to another
If i have 2 different blocks.
I open the first, select some geometry and Ctrl+C
I close and open the second block and Ctrl+V
I see _Paste in the Command but i get a Block Edit dialog with the following:
“You must cancel currently running command first”, i click OK
Then Block Edit window is still on, OK and Help buttons are inactive.
I can select the geometry from both blocks at the same time.
Hi Bogdan- thanks, I see that. Lots of changes to copy/paste and blocks lately…
https://mcneel.myjetbrains.com/youtrack/issue/RH-40576
Hi pascal, thanks.
If possible, please have a look at the snapping problem which I mentioned in a previous post…
