I noticed that there is a chance for an unwanted closure of the Layers panel while typing the name of a newly created layer (or renaming an existing layer). This is only possible when the Layers panel is set to auto-hide mode via the “Toggle the right sidebar visibility” button located the the bottom right corner of the screen.
To repeat the bug:
- either press the “New layer” button and move the mouse pointer away from the panel;
- or try to rename an existing layer and move the mouse pointer away from the panel.
In my opinion, Rhino should not lose focus while the creation or typing of a layer name is still active. I guess that the easiest way to fix that is to temporarily disable the auto-hide feature until the naming (or renaming) is completely finished. Once this is done, Rhino could switch back to the auto-hide mode.
There is no such an issue when the Layers panel is set to its classic permanently visible state.
