Bug: switching material type doesn't show UI
some times I need to switch from one render engine to an other and in this case the UI isn’t shown at the material editor, only at the object properties. Paul from Octane told me that it could be fixed at the Rhino side, so my request here.
Ciao,
Micha
https://mcneel.myjetbrains.com/youtrack/issue/RH-49764
I believe I have just found and fixed this. The fix will be in SR14.
And the fix even appears to be working!
