hi @andy, @paulphysicalc,
I’m trying to use Octane in V6. When I’m trying to create or edit materials in the material tab the entire UI stops responding and gets filled with artifacts. Can you please take a look and figure out if this is a Rhino or Octane problem?
Take a look: https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/d/d/dddb30a9a6111dc285ef6b06f084ad15d43ac7d8.mp4
Thanks!
Gustavo
Another issue, also I can’t tell if is a Rhino or Octane problem:
Diffuse/emissive material properties do not stick. Look what happens after I change active material in the materials tab and I come back to the previously diffuse/emissive material: it changes to glossy material. https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/f/e/fe9f2f8d94dd92a6884b49f7c75786dc5586cd09.mp4
