Bug "Properties:Materials" panel does not show options
Hello there,
my Properties: Material panel does not show any options to change the material.
This is a bug that I frequently see, both in Rhino 7 (latest version) and Rhino WIP. I wrote about the same issue for WIP here: Bug? Properties: Material - Properties are not visible
Is there any fix to this issue?
Hi Thomas -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim,
Thanks. Here are the details:
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13002, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Commercial, build 2022-07-27
License details: Cloud Zoo
Apple macOS Version 12.5.1 (Build 21G83) (Physical RAM: 32Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,4
Language: en-DE (MacOS default)
Apple M1 Max (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 21845 MB
Graphics: Apple M1 Max
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1 Max
Color LCD (1512 x 982 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/thomas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/DatasmithFacadeCSharp.dylib
/Users/thomas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/libtbb.dylib
/Users/thomas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/libtbbmalloc.dylib
/Users/thomas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot10Rhino7Plugin.rhp/libkeyshot_rhino_plugin.dylib
/Applications/KeyShot10.app/Contents/MacOS/luxkeyshotlive6.so
/Users/thomas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp “Datasmith Exporter” 5.0.2.0
/Users/thomas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot10Rhino7Plugin.rhp “KeyShot10RhinoPlugin” 1.2.0.0
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.21.22208.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.21.22208.13002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.21.22208.1002
Hello there,
the issue keeps haunting me. Is there still no fix to this? Just today, I had the same issue on Rhino 7: Rhino does not let me change the color or anything else on any of the materials I use. I think it must be a bug.
Thanks for any kind of help with this!
Yes this is a bug.
Br, Max
Created a YT for the Bug.
https://mcneel.myjetbrains.com/youtrack/issue/RH-72737/Bug-PropertiesMaterials-panel-does-not-show-options
Br, Max
Hi Max,
thanks a lot!
I have fixed the problem.
Hopefully everything will be ok in v7.28. That should contain the fix. If there is still some problems, then we will reopen the YT and make a new fix, but I am fairly sure I fixed it.
Note: I was at least able to fix the case when nothing is shown. The other issue that the current contents own section seems missing is probably caused by the same problem. However I could not reproduce that case. So fingers crossed :crossed_fingers: .
BR, Max
Thanks for the quick fix! That is amazing!
Hi Max, I’m currently experiencing this bug on the latest version of Rhino (7.28.23058.03002, 2023-02-27) on mac :frowning:
How can I fix this?
kindest
Hi @Mohamed2
Do you experience both of the problems presented in this thread. There are two images in this thread. In the first image no sections are presented for the material and in the other case we see some sections like the name & type section but the contents own section is missing?
Best Regards, Max
I see like the first of the images, unfortunately. Any clue or suggestions? :frowning:
I have reopened the YT issue. Have to see what is wrong.
Br, Max
Hi @thelmer
Are you still seeing this problem on Rhino v7 and in the WIP.
Br, Max
Thanks @maxsoder,
I haven’t seen it, but I also did not use Rhino extensively the past few weeks. I will write in this channel if I encounter it again.
Hi @Mohamed2
Are you still seeing this problem on Rhino v7 and in the WIP. It would help us to investigate. Thank You.
Best Regrds,
Max
I have this problem and have had it for quite some time on both my computers. It works for a while but after I switch around materials on models and go in and out from cycles view a couple of times the details view bugs out and stops updating. Can´t create any new materials or change existing, only a restart helps.
Rhino 7 SR33 2023-9-5 (Rhino 7, 7.33.23248.13001, Git hash:master @ 332dda7497b18e9e6f82f118da5cba0c448151a9)
License type: Commercial, build 2023-09-05
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 SUPER (NVidia) Memory: 8GB, Driver date: 9-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.34
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-1-2023
Driver Version: 31.0.15.3734
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23248.13001
@Jens_Nybacka Thanks for the information. I will try out the steps you mentioned.
“Can´t create any new materials or change existing, only a restart helps.” Can you create new materials using the material editor?
I’m currently experiencing the same issue… can you please reopen the YT?
The issue is open. We have tried to fix it, but as we cannot reproduce the problem it is hard. Any hints about what steps need to be done to get the problem would help to solve this. Maybe also a model that has the problem would be great.
