Bug report: some curves can't be edited with cage edit
We encountered a set of curves that could not be updated with cage edit. We had to rebuild the curves, then it worked.
Here are the curves: buggy srfs.3dm (46.0 KB)
Steps to reproduce:
  1. Use _CageEdit edit on the 5 curves
  2. Parameters: BoundingBox, World, 4 x 4 points, degree 3, Global.
  3. Try pulling any of the control cage points in any direction, it has no effect.
It seems to be related to the fact these curves are planar because when we pull the curves control points in the Z direction beforehand then the control cage works. It seems that it’s unexpected though because other planar curves we tested don’t have the issue.
Rhino 8 SR9 2024-7-12 (Rhino 8, 8.9.24194.18121, Git hash:master @ 785b9fde79bb684d22aab317998f7195a8c27c14)
Hi Felix,
To be clear, the file you attached should not work with the CageEdit correct? (its working for me in our latest daily), once you confirm i’ll try rolling back to 8.9
Yes, I explained the steps to reproduce above, _CageEdit doesn’t work on the specific curves that I sent in the Rhino file.
I’m going to send you our latest.
Please run SystemInfo in the Rhino command line and post the entire result. Thanks
It still doesn’t work here:
System info:
Rhino 8 SR12 2024-8-24 (Rhino 8, 8.12.24237.22001, Git hash:master @ 11f7607be80095edf34125493562a8e350ec3f22)
License type: Commercial, build 2024-08-24
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.80
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.80
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 10-17-2023 (M-D-Y).
> Integrated accelerated graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-22-2024
Driver Version: 31.0.15.4680
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24237.22001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24237.22001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24237.22001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24237.22001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24237.22001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24237.22001
Got it!
Thanks for reporting RH-83497
This is fixed in the latest 8.12 and will send you a link.
RH-83497 is fixed in Rhino 8 Service Release 11
