Dear devs,
little bug on DWG export.
Repro:
Create radial dimension
Write something in Prefix
Export as DWG
Open in Autocad (Tested in Autodesk DWG TrueView 2026)
The “once” has been inserted a second time after the dimension “R”. I think the suffix has the same problem.
Relevant files attached.
Looking forward to some response!
Thank you very much,
David
dimTest.dwg (28.1 KB)
dimTest.3dm (46.1 KB)
