When I try to export such dimensions, they are converted into different ones. I used the solids 2007 export scheme.
Thank you in advanced
I see that. It appears to be an export problem, as the Rhino produced DWG re-imported into Rhino, looks just like it does in AutoCAD.
https://mcneel.myjetbrains.com/youtrack/issue/RH-51754
Thanks for the report.
Hi John,
I can’t access the issue RH-51754, is it because it already got fixed?
That YouTrack issue is only open to developers because it has some customer example files in it.
Sorry.
