Python on Mac. I’ve tried everything. It works from the UI, but not from Python.
# You must have a page active and then run the below.
# Works
# Horizontal dimension
start = Rhino.Geometry.Point3d(0, 0, 0)
end = Rhino.Geometry.Point3d(100, 0, 0)
mid = Rhino.Geometry.Point3d(50, 10, 0)
rs.AddLinearDimension(rs.WorldXYPlane(), start, end, mid)
# Degenerate result
# Vertical dimension
end = Rhino.Geometry.Point3d(0, 100, 0)
mid = Rhino.Geometry.Point3d(10, 50, 0)
That works as a workaround! The thought briefly occurred to me, but I wasn’t sure if the planes orientation was used, and I didn’t test it out. Thanks!
From a user perspective I would still consider it a bug: the API gives no indication that this method only works for none-vertical (in plane space) dimensions.
