thanks pascal - I try to post an example with failing inset later.
with bridge there is a one special case - adding additional faces with a bridge should be handled… (meaning it is not a bridge from existing faces to existing faces, but from the subD with reflect to for example a SubDPlane that closes a hole - i will post an example for this later)
