Subd - can't append face or insert point
Commands not working on subd parts with reflect active:
! _InsertPoint
! _3dFace _Output=_SubD _Append
Looks like InsertPoint was already reported as RH-81085
Version 8 SR6
(8.6.24074.1001, 2024-03-14)
Hey Peter, just seeing this… is it still happening in later service releases? If so can you post a file with steps to repeat?
I’ll get it written up-
See also here
Re Append - in the attached file, try to append a face to fill the hole.
Steps:
Create a subd box.
Delete a face.
Turn on Reflect - doesn’t seem to matter where you put the reflection plane, afaik.
Run Append Faces from the subd buttons (or use ! _3dFace _Output=_SubD _Append)
Try to fill the hole.
(Looks like insertpoint is working now.)
appendfail.3dm (50.0 KB)
thanks seeing this here as well-
we’ll get it tuned up asap!
RH-81836 append face fails with reflect on-
this is fixed in 8.8.24135.10001, 2024-05-14
RH-81836 is fixed in Rhino 8 Service Release 8 Release Candidate 1. Please try it out
