Create a 10 mm diameter circle and a 10 mm square on the top cplane
Use gumball to lift both 25 mm
Osnaps - enable end, center and project
Create linear dim for the square and radial dims for the circle
Linear dim for the square projects back down to top cplane as expected but the radial dims do not project.
Rhino Version 7 (7.3.21026.13002, 2021-01-26)
radial dims do not project.3dm (3.3 MB)
Just tested on Windows and looks the same as on Mac - with project enabled linear dims project to cplane but radial dims do not. Is this expected behavior?
Rhino Version 7 (7.3.21026.13001, 1/26/2021)
