is this a bug? would like to drag the circle’s radius manually
Is project and planar on?
Hi Hannes- use the Radius option,then you can click a point and watch the circles change as you set the radius distance. Otherwise, set the CPlane to the depth of the two input curve’s plane.
thank you both! my fault. planar on! thx pascal, better approach def.
Hannes
