DimDimension always projects a circle to the CPlane, which outputs an incorrect diameter. Is there any way to get around this?
The original layout is flat on the CPlane (left circle) and is flowed to the destination (right circle). I tried to flow the dimension with the same curve but Flow will not accept a dimension type.
Example file from screenshot:
DimDimension.3dm (195.6 KB)
BTW, this would be my ideal dimension. I can do it manually with a text block, but then it wouldn’t be tied to the circle for history, be prone to typos, etc:
