Hello all,
Very simple example: I’m trying to remesh a sphere brep and I have an additional circular curve along its surface (via sphere-cylinder intersection). I am running Quad Remesh and providing the curve as a guide curve with the influence of edge loop (2).
here is the code inside the component:
private void RunScript(Brep brep, double targetLength, List<Curve> curves, ref object mesh)
var p = new QuadRemeshParameters();
p.GuideCurveInfluence = 2;
p.TargetEdgeLength = targetLength;
mesh = Mesh.QuadRemeshBrep(brep, p, curves);
some observations:
- half of the time the component fails to generate a mesh. when successful, sometimes it has holes, sometimes it is well-formed.
- this bug seems to be due to the fact that the curve is circular. when I shatter the curve and provide only a part of the curve, it seems to succeed at all times. however, when I shatter the curve but still provide all of the smaller curves into the input, it fails much like if the curve was not shattered.
hope it makes sense. thanks!
