Hi guys,
It’s a long time annoying things: the Z ortho in not keeping the inserted distance:
As you see in the image I’ve inserted 25 but in vertical direction it allows me to move freely at any distance (like 22.9)
Pls add it to the Pile
Is it you @Joshua_Kennedy ? or @Gijs ?
Thanks
If you don’t type space/enter after your number, the constraint will still apply, but yes, this is inconsistent between the axes since the horizontal orthos keep the constraint after space/enter.
RIGHT!
Students while learning get confused from the different behaviour.
Should be more consistent.
