Weird Shift constraint in perspective view
Is there any reason for this?
Doesn’t happen only one time but encountered this behavior often.
Thank you
PS: if I switch Osnaps for locked objects on I would at least manage to work with it but restarting did not solved this SHIFT constraint issue.
I assume you’re referring to z-ortho?
@Gijs is there a way to prevent that? Thank you.
Right click Ortho in statusbar and uncheck ‘Snap to CPlane Z’. In latest WIP this behavior should be better though, being less aggressive.
Great news! Thank you @Gijs
@Gijs can you please tell me where the setting is? Thank you
