(bug) naked / unwelded Mesh Edges not handled correct
(both systems, same behaviour: windows Rh7, mac Rh8)
something is super strange / buggy here:
a spiral-like mesh-Face-Setting.
shaded
in shaded view i would expect that the left spiral is welded at all edges (it is) and the right spiral is a real cut spiral…
showedges vs DupBoarder
looks (wrong but) consistent for this sample
but it is not, and not consistent for multiple copies: ( of the same geometry)
(left showedges, right dupBoarder)
this sample is manually drawn.
i have the same issue in a more complex geometry with this kind of mesh typology generated by code (c# plugin).
its a commercial project and i would need a fast fix or workaround @Gijs - does it make sense to additionally send a email to support ?
thanks
kind regards - tom
BadMeshEdge.3dm (3.0 MB)
this is indeed very odd. Moving the mesh makes it that some of the vertices get welded automatically, at least that’s my impression.
I’ll dig into it a little more and write up a YT
Dear @Gijs
thanks for digging in…
wait a few minutes please…
i set up a workaround yesterday and i will collect a minimal sample script.
Rhino.Geometry.Collections.MeshTopologyEdgeList.IsEdgeUnwelded
my guess: there is something wrong in the underlaying core. ;-(
ok here is a script that shows my workaround and compares it to the result of Rhino.Geometry.Collections.MeshTopologyEdgeList.IsEdgeUnwelded
(maybe i also missunderstand the meaning of this flag ?)
my workaround checks if an Edge has 2 connected Faces and if those Faces share 2 indices.
some dots are on top of each other, so MeshTopologyEdges does init some of the unwelded edges as one edge, some as two edges. (some tolerance issue from the underlaying core ?)
..for sure DupBorder and ShowEdges rely on this mechanism and behave wrong on top of this…
(and the result consist within the dot-pattern, (see the read dots compared with the yellow (dupBorder) Curve)
MeshWeldedBug.cs (2.3 KB)
hope this is helpful - as workaround for others - and for error tracking, further digging and for the devs.
hope for a fix
kind regards - tom
Unwelded does not mean naked
It might be that this behavior is unavoidable, idk. I’ve logged the issue for @piac to look into.
RH-95496 Different naked edges depending on location
I suspect the only way to keep the edges naked is to make sure the physical distance is > doc tolerance
for example, as soon as I flatten this mesh, I get the same issue back:
the docs say
IsEdgeUnwelded
Determines if the mesh edge is unwelded,
or if the mesh faces that share the edge have unique vertex indices.
… though the second condition is a bit vague…
how do you distinguish
welded
unwelded
naked
my workaround is doing what i expect… so i use this
yep.. though of the same test ;-D
i think the idea behind the implementation should allow for what i am after - naked edges that share an topology-edge - or at least are at the same Position / Line.
Otherwise UnweldEdge (command) does not make sense.
Same for Mesh.UnweldEdge (API)
Also - One TopologyVertex can be linked to multiple (Mesh.)Vertices - see MeshVertexIndices (API)
my guess: the implementation mixes in a buggy way:
indexA == indexB
distance < zeroTolerance
distance < geometricTolerance
welding has to do with how adjacent mesh faces are shaded:
Hi @Tom_P
maybe AlignVertices can fix the problem?
Jess
yes i know.
but the underlaying datastructure reflects this:
left - unwelded _extractPt → 32 Points
right - welded _extractPt → 8 Points
unwelded_welded_box.3dm (3.0 MB)
if you compare this box-Example with the helix i posted above - i get 2 extracted points also for edges that are not “unwelded”
and applying weldEdge or weldVertices or unweldEdge also missbehaves on the helix-Example.
thanks for having a look.
my aim is to have an unwelded edge (on the API side) - a cut out spiral …
the problem is, that the data is correct (at least at my point of view) but interpreted wrong ;-(
you can align the vertices by code:
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.collections.meshvertexlist/align
Edit: An edge is not welded and not naked if the adjacent faces use at least one different vertex which is in the exact same location of that edge. Use the MeshVertexList and not topology.
Topology vertices are sets of vertices in the MeshVertexList that can topologically be considered the same vertex.
ok i believe i got it.
box
document-Tolerance 0.001.
one CV is of by 0.00001 → it s two Typology-Edges both considered as unwelded. And as they only have one adjacent Face, there are 4 naked edges reported by showedges.
Point at (50.00000000,25.00000000,50.00000000).
Point at (50.00000000,25.00001000,50.00000000).
spiral
my inital spiral sample shows a naked edge between the “2” (actually 4) Points:
Point 1: X=-7.5477994740063691E-15, Y=103.64784716182231, Z=0
Point 3: X=-8.3340285858820322E-15, Y=103.64784716182231, Z=0
Point 4: X=-17.38920407419057,      Y=108.01874461164527, Z=0
Point 2: X=-17.389204074190573,     Y=108.01874461164527, Z=0
but those pairs of points are of somewhere at 1.0 E-13 - considered as naked.
after aligning them (thanks @Jess ) i suspect they are identical bitwise, resulting in an unwelded edge
Point 1: X=-7.9409140299442007E-15, Y=103.64784716182231, Z=0
Point 3: X=-7.9409140299442007E-15, Y=103.64784716182231, Z=0
Point 4: X=-17.389204074190573,     Y=108.01874461164527, Z=0
i would claim, the bug is the wrong tolerance that is applied here.
spiced up with my confusion between the special case of being naked (but being identical within document tolerance) and unwelded.
kind regards - tom
Hi Tom,
I think the problem is in the low level mesh routines. If you move your spirals away from the origin, then everything is fine:
Looks like the naked check does not calculate the actual vertex distance considering document tolerance but checks more if “is identical” based on mesh precision.
Just a guess of course and I also stumbled over that once.
Jess
hi @Tom_P
just FYI the issue is set to ‘won’t fix’
the behavior is confusing, but there’s no real bug here. Only vertices that don’t share the exact same location can result in ‘naked’ edges.
Edges that are welded or unwelded, have vertices that are shared between adjacent faces.
The model that is marked ‘bad’ is not bad, but can be improved by aligning vertices.
Quote from the developer:
“The problem is whatever created the mesh with nearly-identical but with some rounding noise in the vertices. Meshes are simple in Rhino, and one of the assumptions is that anything that does not exactly merge is open. It’s up to the creator, making sure that the contract is fulfilled. All of this comes from that fact. So, essentially, fixing the script or plugin that created the mesh would make it behave as expected.”
Dear @Gijs
thanks for coming back to this topic.
Above Spiral is a super simplified Version of a 3d-Print Path “spiralize” / “vase-mode”(i hate this word) project.
The issue was that i needed unwelded Edges - that got interpreted as welded.
The Problem first occurred in very rare sections where input Mesh is vertical and also edges are vertical.
I fixed it with a custom script / different algorithm avoiding Rhino.Geometry.Collections.MeshTopologyEdgeList.IsEdgeUnwelded
So at least this Method should be better documented (what does Unwelded technical mean) ( and/or the method should have an overload with a Tolerance parameter - if that makes sence?)
This was a really nicely hidden bug - and for sure it will rarely pop up in other projects of other developers that misunderstand the relation between an created Mesh and the MeshTopology Stuff.
… my 2 cents…
kind regards - tom
The API is not a technical help file, so information about what Unwelded means should not be there imo.
Does this Rhino help file discusses the term sufficiently?
I think the API should give the info, that allows the correct and expected usage.
looks like (un) welded is more than comparing indices, and the used tolerance is not documented.
in other words - already said above:
It makes a big difference if Edges are
welded or unwelded or naked (1 of 3 states)
or
if a naked edge is also considered as unwelded.
The tolerance that is applied here is not documented.
Did you / and or the “dev” look at the script i posted above ?
my custom implementation
bool IsEdgeWelded(Mesh mesh, int edgeIndexTopo)
gives the expected result comparing indices as described in the Rhino help file you linked.
further down i compare the result of my custom implementation with the unexpected result of MeshTopologyEdgeList.IsEdgeUnwelded
bool weldedCore = ! edges.IsEdgeUnwelded(i);
bool weldedCustom = IsEdgeWelded(mesh, i);
The difference is visualised in the dot-colors at the edges mids.
kind regards - tom
