It’s at least the second time this is happening to me, but now I catch it. However, I can’t make a minimal file where this can be reproduced so as an example I will use a slightly bigger file. The problem is visible on many mesh parts but for simplicity, I will focus on one of the wheels.
Can you please take look at it? @Jussi_Aaltonen
System Info
Rhino 7 SR14 2021-12-14 (Rhino 7, 7.14.21348.13001, Git hash:master @ 5ab502b613f84488d00228948505c6f28ebfe598)
License type: Edukacyjna, build 2021-12-14
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 12-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.84
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2021
Driver Version: 30.0.14.7284
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino WIP\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino WIP\Plug-ins\Crayon1.1.1\Crayon.rhp “Crayon” 1.1.0.0
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp “ClippingBox” 1.0.0.0
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “ConnectorRhino7” 2.2.2.7060
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 4.27.2.0
C:\Program Files\SimLab\Plugins\SimLab USDZ From Rhino\SimLabUSDZExporter.rhp “SimLab USDZ Exporter”
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Notilus_Clipper (eccc432b-7947-4008-a2ac-6c7e27f58a93)\1.0.0.0\NotilusClipper\Rhino 6\Notilus_Clipper.rhp “Notilus_Clipper” 1.0.0.0
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.3\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.3.0
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.1\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.1.0
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.1\Substance.Win.rhp “SubstanceImporter” 2.0.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\export_OBJ.rhp “export_OBJ” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\import_OBJ.rhp “Import_OBJ” 7.14.21348.13001
Files:
unweld Start.obj (6.4 MB) - start file
blender export to OBJ.obj (5.7 MB) - file re-exported in Blender
two meshes.3dm (4.7 MB) - both meshes in Rhino file
I’m working with Rhino 7 and RizomUV 2022.
Rhino unwelds some of the mesh edges. Once they are unwelded further “unfolding” in RizomUV produces bad results which break my work.
This is a work in progress file where I do unwrapping, many parts of this mesh object show this behavior but please focus on one of the wheels.
Example
RizomUV
Please take a look at which edges are unwelded.
Exported from RizomUV as obj and imported to Rhino 7
Rhino during import unwelded some random mesh edges
Exported from RizomUV as obj, imported in Blender, exported again to obj and imported in Rhino
Importing the obj file in Blender 2.83 first and then proceeding to Rhino made me avoid this problem and it shows that there is something strange on the Rhino side.
