In Rhino 7 when I Use a new material > rename that material, the entered text resets to default after about 8 seconds. This has been happening since the official release of RH7 for me.
Hi Derek - Please run the SystemInfo
command in Rhino and copy/paste the results here. If possible, can you please also grab a short video clip or provide blow by blow instructions to repeat?
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19001, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Commercial, build 2021-05-07
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 2-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.72
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-23-2021
Driver Version: 27.21.14.6172
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\Derek\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\5.0.1.0\XNurbsRhino7.rhp “XNurbs”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
This video shows creating a new material and I noticed:
If I move the mouse after finishing typing the material name it does not reset.
If I don’t move the mouse after typing the material name it does reset.
And when I go to re-name a currently existing material, a similar thing happens: it resets to what it was named beforehand. However, this glitch only happens once and is not repeatable, unlike the above glitch which is repeatable every time I try it.
I’m impressed that you responded so quickly on a Sunday evening, thank you Pascal.
