Material re-naming bugs
Hi McNeel
I’m seeing a weird bug when re-naming materials in the material panel. Sometimes I can change the name, but as soon as I press Enter to confirm, it reverts to the old name. Then I can slow-double click to make the name editable again, and the recently changed - but not displayed - name is back. Once again press Enter and the name reverts to the old name again… and back and forth… and then suddenly it sticks. I see no pattern in the behavior as yet, but will try to find a repeatable example.
And can I please have an option to automatically sort material names alphabetically, in order to avoid having to right-click and locate “Sort Alphabetically” every single time I add a new material or change a material name (if I can!).
-Jakob
Can you run the SystemInfo command and send me the information?
Hi @maxsoder
Of course - my bad!
System Info
Rhino 8 SR12 2024-9-17 (Rhino 8, 8.12.24261.13001, Git hash:master @ 8259b0e5b4454adebdaa738e9d738a475418afda)
License type: Commercial, build 2024-09-17
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 95GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 31.0.15.5286
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24261.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24261.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24261.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24261.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24261.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24261.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.12.24261.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24261.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
C:\Users\jn\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
-Jakob
@Normand I have a few followup questions. Are you renaming in spot 1 or 2? Is it the material editor (grid/list/tree view) )or material properties panel, layer material dialog?
Hi @maxsoder
Yeah, sorry for the lack of info - was in a bit of a hurry. Here are a few more details. This is in the properties panel, in tree view. Next time it pops up, I’ll try and change it under “Name and Type” instead and see if that makes a difference!
Regards, Jakob
Thanks @Normand. I have tried to reproduce for a while now, but with no success. When the problem comes back the next time it would be great if you would be able to take a video of it.
Hi @maxsoder
Here you go - a video. As you can see, editing the name in the lower portion of the dialog box works, so it’s “just” the tree view that doesn’t update.
-Jakob
hi @Normand does that issue persist when you close and reopen the file?
I could not reproduce it here either, and wonder what you are doing differently. Its helpful to provide a file if is file specific.
Hi @Gijs
No, a restart “resets” it, and all is well for a non-specific period of time - and then it comes back. Once it starts, it happens to all material name changes in that file until I restart. I see it happening more often/faster in files with many materials. I’ll try and see if I can make a repeatable file for you guys to look at. At least I now know that I can just use the “Name and Type”-box to make it stick, which I guess kinda reduces it to a paper cut :slight_smile:
-Jakob
Perhaps you can figure out if it happens definitely after a certain time - perhaps 10 minutes, longer, shorter?
