i met some little bug - see gif. If i need rename material, i need type name twice for this change. After first typing i get only “standard name”
hi @Chita I cannot reproduce that here. Pls run _SystemInfo in Rhino and post back the results, thanks
Hi @Gijn, thank you for reply, System info is here:
System_info.txt (3.0 KB)
hi @Chita you mistyped my name, so I did not see your reply to this thread.
Can you try updating Rhino to the latest SRC (2 at the time of writing) and see if the issue persists?
hi @Gijs - sorry for mistaped your name…I try latest SR - CR - problem still persist…
hi @Chita I just checked in 8.2.23341.13001 and can indeed repeat this issue. Since this is solved in the internal builds, I guess you will have to wait until 8.3 RC
