Hello I mainly use WCS mapping on object and for specific orientation I use OCS to change direction, but using Rhino render, it only use WCS and does not apply OCS…
On left Raytraced viewport, on right Render viewport
Right is the correct with vertical legs mapping
Hello @nathanletwory I know that you you maybe have an idea Is it normal that the mapping WCS with a specific OCS by object only work in rendered mode? and not apply et Raytraced mode?
Maybe is it not the best way to proceed…
