So, I applied wood materials on a door and its rails, and used “ApplyMappingSCU” (French “AppliquerPlaquageSCO”,not sure of the translation, I couldn’t find the exact command.)
It works fine on regular perspective render, but when I try to do a proper render, the grain becomes much wider and it doesn’t look like wood. Any idea what must be done?
@REMI_05_COSTAMAGNA ,
Post the 3dm file please of just the door with that material. Use the Export command to save out only the current selection and I’ll take a look.
Rhino render support.3dm (3.1 MB)
Here you go. Not the same door, but the problem is the same, and I built it using the same method.
Thanks for the help.
