Loft/PlanarSrf/Join bug?
Here is a problem I stumbled across. Rather than extruding, I did a loft between these two polycrv and tried to cap. It would not cap.
  1. Select both curves
  2. Loft
  3. Planarsrf
  4. Join
It creates a bad object.
Problem Loft 2.3dm (3.3 MB)
Hello - running SimplifyCrv on the curves before Loft lets that work but I do not yet know why. For some reason the loft does not close at the curve seam point.
RH-57918 Loft leaves open edges
