BUG Line weights are not according to detail view setting!
Again trivial bug which absolutely makes me mad.
Rhino 8 SR11 2024-8-13
In layout space with print display on:
Settings of the detail view:
PDF
Line width does not respect the setting.
I really cant work like this. Please fix it ASAP!
Thank you.
There a few setting that can affect this, if possible please post a small example file illustrating the issue. Thanks
create a box put it in layer color by layer. go to layout create a detail and set some different printwidth per detail. print vector and see that lines are not correct. use wireframe display mode. i suppose that it works with cirves but not edges of polysurfaces.
There are various workflows but the most control per detail might be by using Custom Display modes and checking the Apply Display Mode Scales
no no i dont want any special workflow. i want plain wireframe and edges to behave like they should thus respecting by layer print width defined in layer column. rhino displays it correctly even in print preview but not in printed pdf. there is an obvious bug.
I’m seeing this as well Thanks for reporting RH-83487
make sure color settings work as well. also with cliping plane because i have a feeling it does not work properly. section style color set to object especially dont react to color per detail
