Quick test about clipping drawings and I’ve found a small discrepency.
I was curious why the text dot was selectable in the 2D section since all the layers are locked.
Then I tried to remove that dot and nothing happens. Until I decided to add it back and discovered there were now two of them, the new one being unselectable !
Tested with this week’s release 8.0.23199.14305, 2023-07-18 and the bug is still here for me.
The dot seems to always be created on a Default layer, no matter what layer is active or where the clipping section is located.
If I delete the Default layer it gets reinstantiated when creating the drawing for the first time with ShowLabel = Yes.
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 5-26-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 1-28-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.65
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-28-2022
Driver Version: 30.0.15.1165
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\maxim\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\maxim\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Chameleon_tools\1.0.6\Chameleon.rhp “Chameleon.tools” 1.0.0.0
C:\Users\maxim\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
@magicteddy I see it on your file, but cannot repeat the behavior unfortunately.
Just a wild try, can you perform a OptionsExport and send me the resulting file?
Did you try a factory reset (_Reset) (first make sure to back up you settings with the above)
Another thing I can think of is that this a localization related bug, but let’s first try these.
I just did a Factory reset. Rhino WIP started in French and I have the bug immediately.
I’ll try to uninstall French language pack, then factory reset, then test again in English.
Edit : done, same thing.
Here are the options but it doesn’t seem to come from this.
I suspected this would be W11-related, so I just installed Rhino WIP on another computer where it was never installed before, running W10.
I’m running French environment and French language and I instantly got the same issue.
Switched to English language and factory reset… Same thing.
I’ll try to switch to English environment later on → done and still seeing it.
In addition, if I move the clipping plane, a second label appears and is locked (in the correct layer).
