Bug Report: Clipping Planes with Text Dots in Blocks
Clipping planes sometimes incorrectly make text dots invisible when the text dot is part of a block.
Specifically, the clipping planes clip as though the block were located at the origin rather than at the instance insert location.
Thanks for reporting, can you provide the file and your systemInfo and i’ll get a youtrack going. RH-83833
License type: Commercial, build 2024-08-15
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 112GB)
.NET 7.0.16
Computer platform: DESKTOP
  Primary display and OpenGL: NVIDIA Quadro K5000 (NVidia) Memory: 4GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 475.14
        - Secondary monitor attached to adapter port #0
        - Windows Main Display attached to adapter port #1
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 6-10-2024
  Driver Version: 30.0.14.7514
  Z-Buffer depth: 24 bits
  Total Video Memory: 4 GB
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.10.24228.13001
  C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp	"WebBrowser"
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp	"RhinoScript"
  C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp	"IdleProcessor"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.10.24228.13001
  C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp	"Legacy Rhino Render"
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.10.24228.13001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.10.24228.13001
  C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	8.10.24228.13001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.10.24228.13001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.10.24228.13001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp	"BlockEdit"	8.10.24228.13001
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
Clipping Plane Text Dot Blocks Sample.3dm (1.1 MB)
Your Nvidia driver is getting old enough to become suspect especially since your Rhino is from the middle of August. You might want to update it and see what happens. There was a new Rhino Service Release last Tuesday along with a new SRC. There should be a new Service Release Candidate early this evening Pacific Daylight Time.
RH-83833 is fixed in Rhino 8 Service Release 16
