(Bug) Fractions in Dimensions
There seems to be an issue with adding a fraction manually to dimensions:
  • Clicking the “Toggle stacking brackets” button doesn’t work
  • Adding leading brackets and clicking away does work
  • Adding trailing brackets breaks it
  • If you add only leading brackets and click away, the fraction is created, but then add any character and it breaks
It is working correctly with Text Objects and Leaders.
Screen Recording
System Info
Rhino 9 SR0 2026-10-27 (Rhino 9, 9.0.26300.09401, Git hash:master @ b5c4aa079c11dd91ccd7b6aa067f5029f3fccf72)
License type: Commercial, build 2026-10-27
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 192GB)
.NET 10.0.14
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 10-27-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Cooperlake MAX_THREADS=64.
C:\Users\Domenic Gallo\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Speckle.Connectors.Rhino8 (2153799A-0CEC-40DE-BC3A-01E5055222FF)\Speckle.Connectors.Rhino8.rhp “Speckle” 2026.9.4.0
C:\Users\Domenic Gallo\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\byRhinoGadget\1.6.3\byRhinoGadget.rhp “byRhinoGadget” 1.6.3.0
C:\Program Files\Rhino 9\Plug-ins\Commands.rhp “Commands” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9\Plug-ins\SectionTools.rhp “SectionTools”
Just updated to version 9.1.26314.09001. Same issue.
System Info
Rhino 9 SR1 2026-11-10 (Rhino 9, 9.1.26314.09001, Git hash:master @ e7a246f3aefa1afad39e4dc6c2abb31fa5ca4d6f)
License type: Commercial, build 2026-11-10
.NET 10.0.14
None found.
DirectX Settings
Safe mode: Off
C:\Program Files\Rhino 9\Plug-ins\Commands.rhp “Commands” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\MeshCommands.rhp “MeshCommands” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.1.26314.9001
Hi Domenic -
Thanks, I can reproduce that here.
→ RH-100430 Text: No Fractions in Dimensions
