Multiple stacking brackets/fractions in document user text issue
Text that works correctly in a text object directly is not working correctly when input into a Document User text value and then referenced in a text object.
Example:
My direct text input:
100[[1/2]]" W x 2 [[3/4]]" D x 30" H
The correct output:
The exact same input into document user text:
The document user text input:
Referencing the key in the text object:
The output:
I only have this issue with multiple fractions. It works just fine with one.
Is there a workaround for this?
Thank you!
Does this happen with all fonts?
Hi rhinĂłkerĹŤs -
That issue is on the list as RH-67952 Document User Text: Not Parsing Stacked Fraction Correctly
I’m not aware of a workaround.
In this instance there is one, but it takes a while to stumble on it because multiple factors need to come together.
Store the three dimensions as separate document user text entries, omitting the " symbol, and in the text block precede the first reference with some plain text.
Formatting WorkaroundR7.3dm (803.8 KB)
HTH
Jeremy
Yes this is also a problem in Rhino 8 and Rhino 9 WIP
FWIW, it wouldn’t have been put on the list if this worked in Rhino 9…
Sorry, I only looked at the YT now. Looks like it has been an issue for a while…
