Rhino 8 - Inch Fractional Dimensions, Spacing
Having an issue where inch-fractional dimensions have the space between the full inch and the fraction removed.
In R6, using the same dimstyle setup, the fraction shown below reads as 84 3/4". In R8, either the space is nonexistent or the kerning is weird, because no matter the font it reads as 843/4".
Help? This is kind of a show-stopper.
SystemInfo to follow.
Rhino 8 SR5 2024-1-22 (Rhino 8, 8.5.24022.10001, Git hash:master @ efe42cceb6308fab49d38f3e0332322dcc485b21)
License type: Commercial, build 2024-01-22
License details: Cloud Zoo
Windows 10 (10.0.19043 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24022.10001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.5.24022.10001
Agreed this is not ideal- will write it up as a bug and get it fixed.
in the meantime you can add space in the line in the properties over ride here.
RH-80143 Inch Fractional Dimensions missing a space
When I click on a dimension, the only text that’s shown is <>. I really can’t be going in and manually overwriting all the dimensions I make, the increased time would be tremendous.
(Edit - Oh, I see what you did there. Copying the displayed text, pasting, then editing…still, I can’t be doing that)
For the meantime, I’m having to switch to stacked fractions - our shop prefers non-stacked (so reading as 84 3/4") because it’s more readable for them.
Cheers!
yep, this is a pain point for sure. Thanks for pointing it out.
on the pile, hope to get it tuned up asap-
Hi @ssommerv,
Can you upload a .3dm file that exhibits this?
Thanks,
– Dale
@dale I attached one to the YT
Hi Dale,
It’s kind of a general problem. Any of them that I use, even using the Default dimstyle (when set to no stacking).
I suppose opening a new file and dropping some dimensions in will show this.
Dimension Fraction Kerning.3dm (3.4 MB)
RH-80143 is fixed in Rhino 8 Service Release 4
