BUG | Edit Blend Curve on edge
As I now know how to edit an adjustable blend curve, I use it a lot.
I’m facing a bug when I make a blend curve to an edge insteed of a curve. It seems that rhino looses the position reference on the parent edge and it is worst after each edit.
I put some screenshot to understand the bug and how to replicate it.
Making the blend curve
First Edit
Second Edit
Thanks.
Hello- I cannot repeat this in the current builds - can you please post a file that shows the problem?
Hi
Here is a file with a blend curve, an edited blend curve and a two times edited blend curve.
EditBlendCurveonEdge.3dm (82.6 KB)
Thanks
