If I dimension some points in a rectangle with DimAligned there is some weird behaviour when I change the text height.
As seen in this video:
I have a rectangle with 4 points.
From the bottom left corner I use command DimAligned together with the Tab key to (not sure if that is important but just to be sure) to locate these points.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
I did some tests and there might be some bug with the point snapping.
If I use the point just for intersection snapping with the line it works well, but when I restrain the direction (tab) and click on the point it doesn’t.
I mean, the dim lines appear just fine as look as expected, the problem only arises when changing the text height in the properties tab.
Hopefully someone can look into that, although I’m not sure if there’s anyone I could tag to raise the issue.
Then I suspect its in combination with an annotation style?
I saw this in my test file. I’m not sure what overwrites its removing but maybe you have more knowledge about this. Maybe its a setting that is then causing the problem when changing text height.
.NET 8.0.14
Primary display and OpenGL: NVIDIA GeForce RTX 2060 SUPER (NVidia) Memory: 8GB, Driver date: 3-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.30
Accelerated graphics device with 4 adapter port(s)
Secondary monitor attached to adapter port #0
Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 3-8-2023
Driver Version: 31.0.15.3130
Total Video Memory: 8 GB
ah, it took me a while to see what you are doing. You are constraining orthogonally and then click on the point, so the point is the location that gets registered, and not the projected point.
RH-89220 DimAligned / Dim issue with tab constraint
As a workaround, instead of clicking the point, hover over it and click on the intersection of the vertical/horizontal and its tracking line.
