@kike in the WIP(9.0.25077.12305, 2025-03-18), there is a Text Height difference between GH and Rhino when baking aligned dimensions.
Try this file:
GH-R9 WIP Dimension issue.gh (20.5 KB)
In the vid below, you’ll see R8 (correct) and then the WIP, in which I need the text height set to 150, but I need to use a setting of 2 to display it correctly in GH. Notice how R8 works fine with the setting of 150.
It’s a Large Objects MM template file.
