Rhino Aligned dimensions
Any hint why changing the dimension settings like arrrow size & fit text shifts the dimension?
Hi M -
Please run the Rhino SystemInfo command and copy-paste its output here.
Rhino 8 SR25 2025-11-10 (Rhino 8, 8.25.25314.11001, Git hash:master @ 305475a429872768e321960d34ed215b72a0da18)
License type: Commercial, build 2025-11-10
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9310.0
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display and OpenGL: NVIDIA RTX 5000 Ada Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.24
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
    Primary OpenGL: NVIDIA RTX 5000 Ada Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.24
OpenGL Settings
Safe mode: Off
GPU Tessellation is: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-22-2024
Driver Version: 32.0.15.6624
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\SOFiSTiK\2024\SOFiSTiK Rhinoceros Interface 2024\Loader\sof_rhino_interface_loader.rhp “SOFiSTiK Rhinoceros Interface Loader” 0.0.0.0
C:\Program Files\SOFiSTiK\2024\SOFiSTiK Rhinoceros Interface 2024\Contents\sofrhino.rhp “SOFiSTiK Rhinoceros Interface-2024”
C:\Sweco\Rhino\SwecoRhinoPlugins.rhp “SwecoRhinoPlugins” 1.1.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.25.25314.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.25.25314.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.25.25314.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.25.25314.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.25.25314.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.25.25314.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.25.25314.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.25.25314.11001
Hei M -
Note that the current version is 8.27.
I’m not able to reproduce that issue here (with 8.25 on macOS).
If this is something that is reproducible on your end, could you make a new file and save that in the state before the change and post that 3dm file here?
