Hello!
Can you please open this file… test contour.zip (73.0 KB)
… and select this curve:
‘What’ says it’s closed, valid, and has 20 segments, but the ‘Area’ command does not compute.
Interestingly, just by moving the curve, or creating a copy, it becomes valid! ‘What’ will then say it has 16 segments.
Please use normal .zip, many people cannot open .7z without downloading an external app.
Without opening the file, I suspect you might have a micro sliver surface in the object you’re slicing which will translate to invalid microsegments in the contour curve(s).
_SimplifyCrv
will solve your problem
just run it after _contour to get proper polylines
(seams like _contour is designed to output polyCurves, one segment per Surface - and does not focus on outputting something special if everything is planar. But of course it would be nice if the output is filtered for small zero-length line-segments, therefor you might call it bug - @pascal has to decide this)
My guess is anything that replaces the object also does some cleanup - Explode/Join also sorts it out.
I’ll see if we can get this fixed, thanks for the report. RH-67779 Contour messy output
(If I contour this object, the one at that level is in two pieces)
