Today I found errors on a script that I check regularly in which everything is fine normally but today I opened it and it is messed up. I pinpointed the error on duplicates out of the Contour component. I created a simple example to check if I was crazy but indeed I get double the curves I should get. The duplicates are present as extra branches.
I think the error occurs after the last Rhino update.
Does anyone get the same bug?
ContourDuplicates.gh (12.4 KB)
