circle command does nor autocomplete, pulling the diameter quits the app
Circle and many other commands are not implemented in iRhino
RV-1127 Circle Command Makes iRhino Crash
thanks for the tracker, you write that dotnet is needed, what does that mean for this command and some others which also may depend on it if they do?
Aside from the UI, iRhino uses the same code as Rhino. And .NET is one of the major dependencies of Rhino.
We need to figure out how to run .NET on iOS for all of this to work. We’re making progress on that but not quite there yet…
