I am new to CAD and learning all about this. I am having a problem with Rhino 7 SR32 locking up every time I use the circle tool and input a radius. As soon as I hit enter after typing in a radius number the computer freezes and I have to hard reboot. This is repeatable. I have used the program on two other computers that I have and this does not happen using the same project file, so I am sure is is some setting with my laptop.
Please run the Rhino “SystemInfo” command (you can type the command name), and post the results.
This will give us a good idea of the computer resources Rhino sees on your system.
Hopefully something obvious will stick out and suggest a fix.
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 9-30-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 30.0.100.9929
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 30.0.100.9929
Driver Date: 9-30-2021
Driver Version: 30.0.100.9929
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Unfortunately, your computer does not meet Rhino’s minimum System Requirements; primarily because of the inadequate Intel Iris display adapter.
Compounding the problem is it’s driver is quite old.
