BUG: Block manager in Rhino 7 resets the width of the fields
BUG 1: I noticed that in my Rhino 7 the width of the fields (Name, Link Status, Link File Name) will always reset upon the next time I open the pop-up window. Is there a way to make it remember the custom state? I’m tired of being forced to shrink the super wide “Link Status” field that consumes a lot of space for no reason, then expand the “Name” one.
BUG 2: Upon mouse hovering Rhino 7 will not show the full name. This is especially needed when the file name is long or the field is narrow.
BUG 3: I can’t find any button that enables export of a selected block as a new 3dm file (as a pure geometry, not as a linked block) that preserves the current position and orientation of the linked object(s). The existing “Export” button does nothing when I press it.
BUG 4: The ! _SetObjectDisplayMode command fails to affect the inserted blocks.
In Rhino 8, when right-clicking a linked block definition in the Block Definitions panel, the Export menu item shows up enabled, but clicking it does nothing. For embedded block definitions, it pops up the Export dialog.
Using SetObjectDisplayMode with linked / embedded block instances doesn’t change the display mode of those blocks (it doesn’t seem to do anything), the blocks follow the view display mode. The command works on normal objects.
