V5 file opened in V6; annotations scaled incorrectly.
Holes for End Plates and Nest Blocks.3dm (667.4 KB)
Sensor Bracket.3dm (205.7 KB)
Hi Don,
Thanks for the files.
I will investigate it soon and I will let you know what I find out.
Sincerely,
Mary Ann Fugier
McNeel Technical Support and Training
Seattle, WA
Hi Don,
Thanks for passing this on to us.
Here is what I see in your files:
The radius and diameter dimension loose their suffix when opened in Rhino 6.
Text that was inside the linear dimension has been located on the outside with the arrow.
The linetypes are the same, but you need to zoom to see them accurately in Rhino 5. Rhino 6 displays them even zoomed out, and that is a feature of RHino 6.
Let me know if I missed anything.
I will get these two issues logged and add the tracking numbers to this thread soon.
Sincerely,
Mary Ann Fugier
Seatte, WA
Mary,
I’m glad you caught those two issues, unfortunately they are not the issue I was reporting. Look at the values of the ordinate dimensions you posted above in item 1.
Thanks,
Don
Links won’t work for me.
Thanks,
Don
They should now…
Thank You!
They work now.
RH-47471 and RH-47476 are fixed in the latest Service Release Candidate
