Hi! Everyone
It looks like Brazil in Rhino 7 is very slow. Slower than on Rhino 5.
Any solution?
Meir
It works better now but still I think Brazil is a bit slower on Rhino 7 than on Rhino 5 (I didn’t update Rhino 6, I updated from Rhino 5 to 7)
When I close I get this massages, I don’t why?!
I believe you have probably made a change to the Brazil toolbar directly. On exit this change is being saved, but that fails because it is in a location for which one would need an elevated account.
Not sure how to get around it - maybe ToolbarReset? That will lose all toolbar modifications, though. Probably a good idea to create a toolbar RUI that isn’t called default, nor as the brazil toolbar RUI file.
The second message means you have elected to save the textures with your file. Rhino wants to know if you really want to continue, since it is quite much (52MB). If you don’t want to see this dialog anymore simply check the box, and answer either way - the answer Yes/No you give now will be used always in the future.
I would choose Yes if you intend to share your files with other people.
Brazil AND Bongo? You must be a masochist!
Thank you!!!
Hi!
What would you offer for me?
I am hesitating about rendering software. with animation
