Have clean install of
Bootcamp
Windows 10 Pro
Rhino 7
on a MacBook Pro
Rhino runs nicely and then freezes about a minute into opening a file. Any thoughts would be appreciated. And OH-Duh, my main machine is powered off while I use the same license on my laptop is that a problem?
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 7.9Gb)
Primary display and OpenGL: Intel(R) Iris™ Graphics 6100 (Intel) Memory: 1GB, Driver date: 9-29-2016 (M-D-Y). OpenGL Ver: 4.4.0 - Build 20.19.15.4531
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.4 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.4
Shading Language: 4.40 - Build 20.19.15.4531
Driver Date: 9-29-2016
Driver Version: 20.19.15.4531
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Older versions of Rhino were indeed actually designed to run on a potato, but that meant very poor OpenGL performance. With V6 that changed, exponentially better performance with any kind of decent video card, but at the price of you really should have a half-decent video cad.
I would want at least a 512GB SSD, and an NVIDIA GeForce RTX with a minimum or 4GB VRAM (for one monitor), and as much VRAM as you can afford if you want multiple screens and rendering.
If you’re not doing much rendering and only running on a single screen, then pick an RTX with 4 GB VRAM
Several months ago, I picked up a Dell “Alienware” X14 with an i7 processor, 1TB SSD, 16GB RAM, and an Nvidia GeForce RTX 3050Ti (4GB VRAM) portable for $2k.
That might be a good setup for your needs.
No one can really recommend what laptop to get, sorry if I sound like Morpheus, but they’re all a compromise of performance and portability and cost, what you want in a laptop is up to you.
